Need a trigger
bflynn
Need a trigger
Post by bflynn »
Im trying to make a trigger that will trigger an output once every 2 secs. Any ideas? or a tick that would trigger once every 1.5 to 2 secs?
Thanks guys!
Morph
Re: Need a trigger
Post by Morph »
Using the Timer primitive:
BTW i wonder where is the Counter primitive in FS2?
bflynn
Re: Need a trigger
Post by bflynn »
Thanks Morph!!! Thats way better than the one i came up with!! I'll give it a try tomorrow and let ya know.
Thanks again
DSP
Re: Need a trigger
Post by DSP »
This is even simpler:
Both this and the one from Morph use the Windows Timers, which are not very accurate but fine for display etc.
If you want it to be super accurate you can make one using the Ruby module, this uses a different more accurate timers.
bflynn
Re: Need a trigger
Post by bflynn »
Thanks guys. This is what I came up with. This gets me the output i needed. A continuous cycle.
DSP
Re: Need a trigger
Post by DSP »
Nice :)
