Zero Delay Feedback Filter
Re: Zero Delay Feedback Filter
Post by KG_is_back »
I've tried switching the filter outputs (lpf0 and lpf1 before downsampling) and it seems to fix the issue. The output seems additionally lowpassed that way (but that might be the work of oversampling lowpass filter)
tor
Post by tor »
thank you for trying to help. but that is not the right fix. it just makes a notch at nyquist. it is correct only when the two curves entirely correspond.
FIXED... added one sample delay to in1 and out0 ...the feedback probably goes in opposite direction than it should be. (like x0,y0 are actually in feedback)
ZDF filter OS DP fixed.osm
(29.27 KiB) Downloaded 1513 times
tor
Post by tor »
wow, thats close :)
i added HP and BP, but sadly the fix does not work on all filter types. so the search goes on... :cry:
ZDF filter OS DP not yet fixed.fsm
(33.03 KiB) Downloaded 1424 times
and thanks a bunch for trying :D
Here, this one is fixed for good...
gotta separate the two parts of the filter to maintain right execution order. To transfer double precision values between modules I used round and difference, so the feedback is still DP.
ZDF filter OS DP fixed2.fsm
(30.92 KiB) Downloaded 1470 times
tor
Post by tor »
sorry KG, this behaves just like my non working version. i hope maybe Trogluddite can provide an explanation what is causing the trouble here. it is quite strange to me as the non OS version in DP works perfectly well.
ZDF filter OS DP not yet fixed2.fsm
(32.38 KiB) Downloaded 1462 times
tor wrote:sorry KG, this behaves just like my non working version. i hope maybe Trogluddite can provide an explanation what is causing the trouble here. it is quite strange to me as the non OS version in DP works perfectly well.
Now that is very strange... my fixed version works perfectly here... I'm still using Flowstone 3.0.2.0
tor
Post by tor »
If you look at the yellow graph when you sweep filter frequency towards 20khz you see that it warps and then disappears. You have also left out the regular OS filter type selection so you can not in your example compare the regular (grey curve) and the DP (yellow curve) when selecting different filter types.
here's screenshot
tor
Post by tor »
i see that, but what happens to the yellow curve when you change filter type to BP or HP?
*Edit: Here with me your second fix shows that the yellow curve is warped and the disappear near 20khz and the grey curve just stays at LP filter type.
