More with MV Sync
Re: More with MV Sync, and a couple of probs
Just leave it here, for no particular reason other than - Maggi :mrgreen:
Is that a steak sauce?
It's Germany's most famous liquid spice that is just used in almost every meal (well, it used to be at least). It's distilled from wheat, further hydrolysed and "refined" with artificial flavours. There's really nothing natural in it. It tastes salty, meaty and reminds a bit of garden lovage.
For decades you could see Maggi even on the tables in restaurants, right next to salt and pepper. And a spring vegetable soup without a dash of Maggi is like a pizza without cheese :lol:
@ Spogg - I tried using the MIDImono prim to switch between the two knobs, but it won't return to outputting integer 0 when no notes are being played. Also, even when it's essentially working, there's the inherent problem of when playing legato and the second held-down key is released, the MIDImono switching returns it to the setting of the Stoccato control, when it should remain at the Legato time.
maGGi 70_2porta.fsm
(2.81 MiB) Downloaded 1254 times
The MIDImono prim was my only shot at maybe achieving what you want. :?
As you said before, I think it would need a Ruby MIDI solution which would only be utilised when 1 voice was selected. That needs a Ruby expert…
De-zip in poly stream:
Ages ago I thought you could do this and in some situations it seems to work but, as I recall, trouble flares up when you play chords and there are other issues I can’t remember now. I just learnt the hard way never to do it. And I agree it’s misleading to have a poly input on the prim. It should be shown as green.
It makes perfect sense that an LFO waveform for amplitude control would cause clicking at the “discontinuities” and square wave modulation would be the worst offender.
adamszabo
Post by adamszabo »
Guys, this was mentioned before but all of you who are using "ADSR optimized exponential by MV", make sure you update the code because there is a bug in it and your project wont work in newer FS versions because thats more sensitive to errors. On line 53 the last part "addps xmm1,xmm41;" should be "addps xmm1,xmm4;". Please update this in all your synths or your libraries in martins exponential envelope.
Thanks so much - I missed this first time around.
Both schematics have been updated, with some other changes as well.
djbrynte
Post by djbrynte »
k brown pls can u make an virus c emulation :) or an clavia nord lead.
Ur so damn skilled in ur stuff i admit it.
Ur hardcore dude!
I often check ur stuff. Some times i open to learn some to!
Its very intresting synths you have K brown.
That's very flattering, but the Nord Lead's already been done (the fabulous Synth1), and the Virus has too many functions I wouldn't know how to do, I'm afraid. Then again, I think you might be ribbing me.
Both schems updated since Spogg's changes, includes them and a few more; don't use the one Spogg posted, it's not the latest version.
Thanks
