String Orchestra Synthesis
Re: String Orchestra Synthesis
Spogg wrote:I can’t pretend to understand your explanation unfortunately
Glad I'm not the only one :? :oops: :D
Then I did a terrible job explaining it. Let me try again.
Suppose you work at a company that makes regular deliveries to some destination. You meet monday morning and plan for the week. Let's say item A is due every other day, item B is due twice a week and item C is due every day. Your schedule could look like this:
Monday     ABC
Tuesday      C
Wednesday  A C
Thursday    BC
Friday     A C
Saturday     C
Sunday     A C
The rest of the week you just deliver according to your schedule.
Not sure the analogy is clear. If you prefer (simplified pseudo-)code;
float position[k];  // next spike from voice k
float period[k];    // period for voice k
float wav[index];   // wavetable
every 512 samples do{          // prepare schedule for next frame
  for all voices k do{         // schedule all spikes from this voice
    p = position[k]
    while p < index + 512 do{  // add spike and increment position
      wav[p] = wav[p] + 1
      p = p + period[k]
    position[k] = p            // store new position
every sample do{               // read wavetable
  output = wav[index]
  index = index + 1
adamszabo
Post by adamszabo »
Very cool Martin! Can one convert this to poly or its designed for mono only?
Please be patient with an old fool (me).
The impression I get reminds me of wavelet granular synthesis:
-There is a defined 512 sample waveform table.
-Information as to how this is read comes from within a “spike”. This determines the readout rate of the index and the start value of the index.
-The spike happens once per desired cycle period and is just to initiate one complete cycle. In between spikes the oscillator gets on with reading out the waveform.
-In this way the spike is a single sample data word which is, in effect, being sampled and held for one cycle by the oscillator.
How far off the mark am I? In kilometres please. :lol:
If I have indeed got the idea right, what is the waveform in the waveform table?
Yes, essentially it is a wavetable, however one that is constantly being (over)written. The resulting waveform is an overlay of hundreds of spikes, so quite random looking and constantly changing. Here is a snapshot:
adamszabo wrote:Can one convert this to poly?
Good question. My intention was to provide a poly version of this, however so far I haven't found a way how to do it.
I was a little unsure if 'Randy 2' is intended to supplant 'String Orchestra' or what - Martin said back in Nov. that he was 'adding stuff'; is that what became 'Randy 2'?
Anywho, I did a third version of SO, with a second 'generator' that can be tuned to semitone intervals with the first and has it's own Phat and Width controls. With this tuned to say a fifth above, it's Phat and Width at near minimum, one gets almost a soloist-with-orchestra effect. Also added a LoCut to the wet of MVerb 7b; keeps things from getting muddy with bass-heavy sounds - also sounds more like a real world concert hall. Most good halls have much less reverberation at lo freq than high.
StringOrchestra2 copy.jpg (141.16 KiB) Viewed 21316 times
SOS_arpGUI_d2.fsm
(2.06 MiB) Downloaded 1264 times
I really love this thing. Haven't explored Randy2 yet.
Martin - just noticed, inside Randy2 the verb is called MVerb 8B; is this an update or a typo?
k brown wrote:Martin - just noticed, inside Randy2 the verb is called MVerb 8B; is this an update or a typo?
It is supposed to be an update, basically making the echo build-up softer. Not sure if I shold keep it - it is quite CPU hungry.
