Optimizing Filter Module
Hi community!
I have found this quite light and easy to use filter ( attached) yet from analyzing the LPF and HPF I see a slight resonance in the response (with Q = 0 ):
not sure which part of the code is responsible for it ... Can someone help in making it flat ?
Also is there a way, since this is a 8/db per octave filter , to have a numberbox where we can insert how many db/octave we want ?
(I think that'd be pretty cool and make it so much more flexible
not sure which part of the code is responsible for it ... Can someone help in making it flat ? Also is there a way, since this is a 8/db per octave filter , to have a numberbox where we can insert how many db/octave we want ?
- FIlters.fsm
- (18.69 KiB) Downloaded 1491 times
Re: Optimizing Filter Module
For flat response search for butterworth filters (here and SM forum).
I was peeking for some similar filters and how to change the db/octave thing , yet I couldnt find a specific LPF and HPF along with a db/octave option wich Is the main module I need
, I hope this is something you or someone can help me with ! thanks
This looks very much like a Butterworth, Im on the older synthmaker so cant check.
But, the response has a little bump because its a 2nd order filter, so you have to delete the suspected "highpass" section and youre good to go. Seeing this.. I would actually prefer this one over whatever you make of it but thats a matter of taste I guess. Also you can see if the resonance parameter has a setting other than 0, and set it to negative or zero.
192k @ 8ms
